VVT Replacement Solenoid
what is your method? are you simply cleaning the throttle body?
I usually pull off the intake pipe, pull out the maf and spray the crap out of it with maf cleaner and set it to the side to dry, then I get a soft rag (one that doesn't leave lint) and spray both the rag and the throttle body with throttle body cleaner and just hold the plate open with a finger while I clean all over with the rag, it's ok to be generous with the spray wont hurt anything, usually give it a good 2-3 times over reaching in the intake as far as I can, when you don't get any more black smudges on the rag then you know it's clean enough. then put the intake pipe back on and put the maf back on. sometimes when you use a lot of the cleaner it can make it idle a little rough for a second or two when you start it back up but it clears right up.
only tip I can give you is DO NOT pull on the throttle plate hard, just hold it enough to keep it open it's only going to move so far and stop, then just make sure you have the intake all back on correctly and tight, if you get it back on ****-eyed it can suck unmetered air in past the MAF.
Just went out and did it, this is before and after the shadow on top of the plate is just from the light, as you can see it doesn't get very dirty since I keep it clean, seen some that are caked in black soot like a dirty chimney
T
thompsoj22
This is my idle
Ok, im a believer now! That is smooth as glass and as soon as the oreilleys opens ill get a can of maf cleaner. the maf elements look like some type of sediment are on them and the throttle plate has got some soot/blowby residue buildup so ill get that also. Thanks! I want an idle like that, these vehicles are so luxurious to ride in and my idle has never matched the ride!
T
thompsoj22
that's a little itty bitty thing, it will fit right up front no problem
that would be wayyyyy to easy. im going to lay on my back under the front bumper and fabricate til my knuckles bleed until i wish i would have simply done what is proven to work, trucool 40k in front of the radiator. It is different in that the stacked plate/fan design make it really functional for it's size and slow climbs/stop and go it operates at peak efficiency, plus all the trans heat is eliminated from in front of the radiator. We live in the high desert in ca and the season of the death star is allmost upon us, it could be 100+ for june,july,august.
that would be wayyyyy to easy. im going to lay on my back under the front bumper and fabricate til my knuckles bleed until i wish i would have simply done what is proven to work, trucool 40k in front of the radiator. It is different in that the stacked plate/fan design make it really functional for it,s size and slow climbs/stop and go it operates at peak efficiency, plus all the trans heat is eliminated from in front of the radiator. We live in the high desert in ca and the season of the death star is allmost upon us, it could be 100+ for june,july,august.
You could cut a spot right in the center of the front splash guard and then reinforce it with metal brackets I don't think that would be very difficult
jrmhokie
