bigdog9191999
as title says, have an 03 denali and the air pump/shocks don't seem to be doing too much good these days, and I don't want to spend the money to fix it all back to stock. a while back I found a good deal on some shocks so I grabbed enough that I could put on it if I needed too. the issue is, if I pull the air shocks off and put standard ones on will I have ride issues like the nivomats cause?
I swapped some nivomats off my Tahoe ( was wrecked) and grabbed the springs off my avalanche and put on with standard shocks and it rides great as the avy did, but it made it a bit high in the rear. ( after cranking the bars about 2" it still is raked as much or more than stock)
I know the air ride was removed on my suburban before I got it and had standard shocks put on, but it is also a 2500 and wont have the sag issues that the coils could have.
so swap them and not worry? or am I going to have to look in to some standard Yukon xl rear springs with out the air ride?
