wanted 3.42 front and rear differentials for 1995 2 door Tahoe
jrsavoie
Illinois
I currently have 3.73 gears
Willing to trade
bowtiefreak
No Quarter
Near Philly
It's a good bit of work for a very minimal change to be honest. I would save the time and effort for something better. If you were changing from 4.10 It might be worth it, but not from 3.73 to 3.42.
J
jrsavoie
Illinois
It's a matter of opinion. If I can find a donor vehicle or somebody that wants to swap I'd be happy.
Guys spend a lot more for lifts and tires with no gain.
I will realize probably 2 mpg but in addition I will get years of an engine running at lower rpms.
Thanks for the chart. I'm currently running 265/70R17 OEM tires off a 2003?
I think OEM for the 95 Tahoe was 245/75R16
I put 800,000 miles on my 89. I may have the Tahoe for the rest of my life.
Might even have it for a year or 2.
Which ever comes first.
The Tahoe is in very good condition except for the drivers door which was replaced with a used door after the daughter did a little number to it. Kind of ticked me off as that door is the only rust on the vehicle.
I am also looking for a NO rust drivers door. Prferably green with gold bottom that was popular in 95.
And the fiberglass piece that goes under the grill.
I missed out on a Tahoe already for $1200 that I could have swapped parts even up and resold.
Not so much labor involved and I would have had what I wanted for a cheap price.
J
jrsavoie
Illinois
I also have to trade
New in Box Superior Axle and Gear 35-2010 & G95410 4:10 rebuild kit Summit $250 shipp
New in Box Superior Axle and Gear 35-2010 & G95410 4:10 rebuild kit Summit $250 shipped to the lower 48
http://www.summitracing.com/parts/SAG-G95410/
Axle and Gear G95410 - Superior Axle and Gear Ring and Pinion Sets
large image
Image is a representation of this part. Actual part may vary.
$215.95
+ compare
Gear, Ring and Pinion, 4.10:1 Ratio, GM, 9.5 in., 14-Bolt Truck, Set
Application Specific Part: Check Application
Estimated Ship Date: 12/13/2010Email this page Share
OverviewApplicationSuggested PartsShow AllLarge Image
Brand Superior Axle and Gear
Manufacturer's Part Number G95410
Part Type Ring and Pinion Gears
Product Line Superior Axle and Gear Ring and Pinion Sets
Summit Racing Part Number SAG-G95410
Ring and Pinion Ratio 4.10:1
Cover Bolts 14
Ring Gear Bolts 12
Pinion Spline Count 30
Ring Gear Rotation Standard
Ring Gear Teeth 41
Pinion Gear Teeth 10
Ring Gear Diameter (in) 9.500 in.
Pinion Shaft Diameter (in) 1.876 in.
Installation Kit Included No
Quantity Sold as a set.
Tool Transmission Lookup
http://www.summitracing.com/parts/SAG-35-2010/
Superior Axle and Gear 35-2010 - Superior Axle and Gear Ring and Pinion Overhaul Kits
large image $157.95
+ Wish List
+ compare
Ring and Pinion Installation Kit, GM, 9.5 in., Kit
Estimated Ship Date: TodayEmail this page Share
OverviewApplicationShow AllLarge Image
Manufacturer's Part Number 35-2010
Part Type Ring and Pinion Gear Installation Kits
Product Line Superior Axle and Gear Ring and Pinion Overhaul Kits
Summit Racing Part Number SAG-35-2010
Cover Bolts 14
Ring Gear Bolts 12
Pinion Spline Count 33
Cover Gasket Included Yes
Pinion Shims Included Yes
Carrier Shims Included Yes
Crush Sleeve Included Yes
Pinion Seal Included Yes
Pinion Nut Included Yes
Ring Gear Bolts Included Yes
Head Bearing Included Yes
Tail Bearing Included Yes
Carrier Bearings Included Yes
Axle Seals Included No
Axle Bearings Included No
Quantity Sold as a kit.
dph1994
