WANTED: Wiring diagram for driver side door
daddyrim
Timmins, on
I believe I have a power problem, where less than half of my driver side door switches seem to have power. I'm trying to determine if its the multi-switch that has failed or if I have a power problem, but I'm not clear which wires should have power coming in etc. Right now only the power mirrors work to adjust, but NOT the power mirror fold, heated seats, power windows or door locks.
Looking for help
Thanks
08HoeCD
I don't have a wiring diagram, so I can't help there.
There are multiple switches under the driver's door trim panel, each controlling the associated window/lock/etc. It's unusual for more than one switch to fail at once, statistically speaking, but the switches themselves are cheap (under $15 each), if that is indeed the issue.
I found that I had to replace one rear window switch and then the other rear window switch within the span of about 60 days. You can swap each of them out in under 2-3 minutes.
DaisyGirl
