Warranty voided?
NYCMIKE
Have a 2015 LT with 36k. Leveling kit installed (3" front 1.5" rear with 33's) I know I still have a warranty. Came across a hard brake pedal I know GM knows about the booster pump going considering there is a class action lawsuit filed. My question is does the leveling kit void my warranty? Anyone know a GM tech or is a GM tech that can chime in? Thanks
Sent from my SM-N960U using Tapatalk
iras1976
Since it's a 2015 you should still be under the 100k powertrain warranty that they were giving at that time . Slip the dude at the service department $50 if you want to make sure that your warranty will be valid .
PG01
Up here to the right
Just came across this post, you get it fixed yet?
I saw something about a vacuum pump gm uses now and its an easy fix.
Level kit shouldn’t impact warranty at all considering the vacuum issue is run off the motor. Gm cant deny warranty unsless said modification caused the issue directly. I forgot the name of it but some lawsuit cleared that up years ago.
As @iras1976 said a 50 spot wouldn’t hurt either.....
mountie
Extended warranty issues can be good or bad, depending on the " GM Rep " in the area your dealer is in. Trust me on this.... Extended warranties can be honored anywhere. Does not have to be at a dealer near you. I had to get a warranty solved 150 miles away, in Parker, Arizona. ( So Calif. rep was a jerk)
