Water drip and what sounds like an air leak near ac accumulator
Shtiv
Seattle
View attachment 280509 Went out to check a few things and noticed a water drop near ac accumulator even though i haven’t driven the vehicle in a as few hours, but i have also noticed a sound of air being released in the same area when the vehicle is running
OR VietVet
Multnomah Falls
Military
Willamette Valley
Pressures working and then equalizing when shut down can cause the noise you talk about. The water drip is condensation dripping from the evaporator out the drain hole and some of the a/c components will have moisture on then during usage and after shut down, especially in high humidity.
bobwit2bs
