Water leak into driver side front door jam/frame/kick panel
08grey
There is a seam under the rubber flaps that runs down the inner fender. If there is a crack it will be impossible to see. You have to try to shine a bright light behind to see if any comes through. You can also do this from inside and see if you see any trace of light escaping on the outside.
R
redemn93
Jupiter, Fl
ill try that tonight. thanks for the tip. i only sealed inside the cowl. didnt think to check outside.
BaMaDuDe87
Bama
I have this problem now. I see two possible areas, but not sure which one is correct.
Or
08grey
That seal on the floor of the car you posted in the pic was my spot. Another member helped me find it. It has a invisible crack I caused all of them with silicone and it did the trick.
A good flashlight sometimes will show light through the crack.
BaMaDuDe87
Bama
Seal on the floor? I'm guessing you are talking about the first set of pics
This one that was under the wiper cowl?
08grey
Yes. Those seals get microscopic cracks. Mine was actually on the floor pan and I would get water when I drove. Cover those with silicone worked for me.
Sent from my iPad using Tapatalk
ramchol76
so, i had the cowl off today and couldnt find the leak. i sealed up the three usual spots (door wire grommet, ebrake cable boot and shifter cable boot) although they wouldnt explain how water is getting here to begin with. i had the cowl off and pumped it with water. no dice.
i think the leak is somewhere in the small space between the fender and the cowl since water finally came in after spraying in there a good bit. i dont think its the door seals. no evidence of leaking there. pulled the A pillar. dry.
any thoughts? time to pull the fender and take a look?
Hi, I have similar leak on the passenger... I narrowed down to water poured between firewall and fender leads to leak in passenger side. Did you eventually remove fender to further troubleshoot?
J Mac
Newport News, VA
After Hurricane Isaias went through here I too have water on front passenger side floor. So I'll be joining the find the water leak party! Just noticed it today but didn't have time to start looking for leak. Good times!
Dave6137
