Water Pump Question???
chip
Tampa
Hey guys,
(For a 2003 Yukon 4.8)
Can anybody (who has done it before) tell me what I should buy to go with my new water pump? I'm gonna head down to the parts store to get a gasket, but I'm a little hazy on this whole "o-ring" thing. Is that for rebuilding the old water pump only, or do I need it with a new pump instal?
Also, besides coolant and thermostat (with gasket), is there anything else I should be getting?
Thanks for the help in advance!
Chip
crmzendrgone
M town Arizona
I would say get the o ring. You should always replace gaskets/o rings with every repair/replacement.
Sounds like that is it pump, gasket(s) and coolant. I would recommend you flush the system when you have it all open. Just stick the hose to it and flush it all out.
blueflamed03
Oklahoma
check belts while you have them off, I replaced both mine when the waterpump was getting replaced.
DESIGN
North Texas
for sure do the belts. It's easier to do the AC belt with the water pump out of the way. I also recommend putting in some Red Line Water Wetter. It's also worth double checking the hoses. I also dropped in a new thermostat while I was in there.
So for me:
both belts
water pump
Thermostat
two bottles of water wetter
chip
chip
Tampa
Yeah, I got belts, t-stat, gaskets, coolant. All the goodies. I just couldn't figure out whether or not the o-ring was a standard part of a new pump instal, or some "redneck rebuild" kit.
Thanks again guys!
Rivieraracing
Might need a strap wrench to get the fan off of the waterpump, if you can't find one, try to loosen the nut with the fan belt on!
chip
chip
Tampa
I have pullers and a manual, so I SHOULD be good. Thanks
Redhoe01
The BDG
Forney, TX
I am about to do my water pump as well. What do these water pumps call for, an actual gasket or sylicone or both. Mine is a 5.3 which I imagine is no different then the 4.8.
chip
chip
Tampa
Well, on my 4.8 there are 2. A gasket and an o-ring. Kind of weird if you ask me. I'm still waiting on the pump itself, so I haven't been able to pulll it apart yet. I'll let you know when I get it done.
