MelloYello95
- Joined
- Mar 25, 2021
- Posts
- 100
- Reaction score
- 129
DejaVu! We (I) went over this a few months back on a separate thread. If you just bought them take them back to the store in which you bought them. If not contact the manufacturer straightaway and explain the problem. If their solutions don't work then ask for a refund. I have found that the problems come from the way they are boxed, stored & shipped. They product lays in an incorrect way and over time the product attains that misshaped shape. It's hard to get out, but not impossible. I used a heat gun with some well placed velcro tape to get them to keep their shape which eventually they do. But if they are new then by all means take them back. They should lay flat as advertised with no adjusts minor or otherwise. Aloha!!
I don't believe that is the issue with our 2nd row. It arrived fine and it initially laid flat in the rear. It is made too wide for the rear. When both rear doors shut, the mat does not lay under the rear door panel trim. It gets pushed up on both sides. So we can can get it to lay flat but as soon as you close both doors, the door panels push the mat edges up again. Its a terrible fit.
