Weird engine problem, plz help!
sopethree
when i start my truck, and dont let it sit for a min or so, and i start driving, i have no power what so ever, just enough to get me moving, mabey 0-30 in like 15 seconds. then after mabey 30 seconds that. the power will totaly come back in like 5 seconds. i have no idea whats wrong, fuel filter? idk
please help me. :emotions122:
SunlitComet
OBS Jedi-Do Good
unknown at this time.
Sounds like something is wrong i open loop mode. Would look at fuel pressure maybe being to high, an egr system malfunctioning, transmission in limp mode or malfunctioning shift b solenoid. Any pulled codes? Does it suddenly get moving in the first 30second if 2nd gear is selected?
sopethree
sopethree
i only get a check engine light if my foot is into the gas for a lil bit. havent checked the code yet.
retorq
Kingman AZ
No use in checking the code bro, just go on the internet, post some vague description of your problem so a hundred different people can give you a hundred different scenarios and even more fixes, none of which will be right.
Dhrusso925
