Disclaimer: Links on this page pointing
to Amazon, eBay and other sites may include affiliate code. If you click them and
make a purchase, we may earn a small commission.
I was looking for the coolant drain plug on my radiator, and found two sensors or something that are unplugged under the truck. Attached are the pictures of each one, black one was on the passenger side and the other was towards the driver side.
those are the ambient air temp sensors, they just clip into the grill or front end, you should be able to see where they go by looking up from where they are dangling
That last one pictured, with blue and green clips is the ambient air temp that displays exterior temp in your center view mirror, mine is clipped along the side of the radiator behind my grille, towards the drivers side of the grille. I believe that’s the correct spot for it.
Glad someone both asked and answered this.
I have one dangling and the clip is destroyed. Only one "latch" is left and the rest is broken brittle plastic.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
