What are you losing
Blueinterceptor
When the max trailering package isn’t
There?
please don’t simply list the build sheet description
Stbentoak
The main thing that I see is an integrated trailer brake. Sure you can add one but why should you have to? I'm sure you may get upgraded cooling possibly, and more of a camera/trailer info set up. But the main thing I'd want is that integrated brake controller.. much neater setup...
I think it also includes the heavy duty transmission cooler? Which is probably a must-have if you are towing long distances and through higher elevations.
SAdude
I haven't seen anything on the '21s towing package about better cooling transmission, just enhance cooling radiator. I think the transmission cooler was part of the previous Gen towing package. I think all transmissions are equal on the new models. I could be wrong but I researched at one point during the buying process and found nothing about transmission differences on new models with towing package.
B
Blueinterceptor
A better question might be. What would I be losing vs the previous gen as in 2019 Tahoe
2021 vs 2019.
Some camera angle stuff. What else?
Yukon, OK
2021 vs 2019.
Most noticeable would be the independent rear suspension, new for 2021. The ride is sooo much smoother compared to the previous generations (comparing to my 2016 Yukon Denali). This also gives more leg room to passengers in the third-row seat. I've also noticed a much quieter ride too.
Gibby13
We have max trailering and I just checked and we have
  • External auxiliary transmission oil cooler
    • Heavy-duty air-to-oil cooler
    • Helps prevent transmission overheating
    • Helps provides optimal transmission performance even when operating under a heavy load or towing a trailer
  • External engine oil cooler
    • Helps the engine generate peak performance efficiently
    • Helps prevent possible engine oil breakdown during high-performance driving or under loads
B
Blueinterceptor
Is this on a 21 ?
nashon79
