the 18th letter
Northern New Jersey
Got out and rode around with the Range AFM installed and it did exactly what its advertised to do. On another note truck was blowing warm air on drivers side for a bit with AC on while I was idling. Passenger and rear were cool although not as cold as I recalled. Drivers side also isn't as cold as passenger with same temp settings when it is blowing cold.
Sparksalot
Bastrop County, Texas
How’s your cabin air filter look? I had similar behavior in thecopcar a while back. The filter was full of pollen.
the 18th letter
Northern New Jersey
I recently changed it and it was filthy. Research suggests my issue might be a blend door actuator problem. Hopefully I can make it the next three months if it is, things will be tight around here until September.
the 18th letter
Northern New Jersey
Trans fluid and filter changed with TVB upgrade. 1 hour drive mix of highway, well 70 at least lol, and city and trans temp didnt go higher than 160 in 80 degree weather. 1 Step closer to road trip :)
GranPrix
Not yet, in about a 2 weeks will do the install
SpyShops212
I am interested in doing the same when my truck needs new pads in the front. Are you upgrading the front calipers & rotors with the pads from the current generation? Please keep us posted because allot of us want the same.
jvrancik
Just got back from the family trip to the Gulf Shores. Put about 800 or so miles on the 2017 Yukon. Pretty happy with it. Only complaint is the driver seat has developed a small creak/squeak when breaking or accelerating. Kind of annoying but other than that it was perfect. Averaged about 19 mpg over all. It gets a bath and vacuuming tomorrow.
Sent from my SM-N960U using Tapatalk
Hey did you ever figure out what was causing the driver seat squeak? I'm having the same issue and it's driving me nuts.
SpyShops212
It could possibly be the vibration sensors in the foam. You could detach the front clips and move them around. You may need to push the sensors back up. I replaced the front seat foams and leather covers on my truck and everything is solid. Check my post a few posts back.
lordmorgul
