well poop, right part number but the cable fitting is not right, was not another one out there to be found either......
going to try a different antenna and see what happens. only spent $8.00 so no big loss.
if nothing else I can buy a oem antenna and stick it under the dash I have the extension cable now
I ordered a different gps antenna if that doesn't work after thinking about it I can make this splitter work just need to break out the dremel and shave some plastic off of one of the splitter connectors and then make a couple slots in one cable end to fit on the onstar module. that way I am not modifying anything already on the vehicle.
fittings are actually all the same (besides male/female) it's just the plastic part that they design differently so you cannot plug the cable in the wrong place.
gtrslngrchris
Drove all over the state today and picked up a set of snowflakes while I was out. I'm thinking a set of 285/60r20 Toyo or BFG A/Ts will end up on them pretty early next week if not sooner. Will I need to hammer the firewall pinch weld flat to fit this size tire with the front leveled or will it get by without? I run 35x12.5s on my 03 2500HD at "stock" height so I'm not afraid of making room just not sure how much room it will require.
gtrslngrchris
I installed a set of Morimoto headlights and discovered quite a lot of broken clips and similar along the way. I'm a big fan so far and I've got the tail lights on the way. Light pattern at night is great and overall a FAR better night experience over stock projectors.
Fox front coilovers should be here soon so I can level the front in time for new wheels and tires. I think the fog lights, other than needing polished, might need to be smoked to match the headlights better.
gtrslngrchris
Morimoto tail lights and my Fox front coilovers arrived today. Since it was 100 degrees outside for the first time this year I wimped out and only did tail lights after 9pm. These things are amazing looking. Driver side fitment is spot on, passenger less so but still looks great. These really upgrade the look of truck if anyone is on the fence. Now I need to sell the Recon-looking pair that I just removed.
rip mattock
