R3cord303
Posse In Effect
Someone said yesterday that you’d need resistors for the hybrid tails to avoid hyperflash- no you won’t because only the brake lights are LED. The turn signals are still incadesent.
Deslugger thing? WTH?Installed that "Deslugger" thing onto the AC compressor.
I ordered it from RockAuto last week along with some other stuff and it was delivered Monday. Figured what the hell, it can't hurt!
I pulled the front up on ramps and removed the 4 bolts that hold the front splash shield on. Once that was off I could pretty much sit underneath with my head between the radiator and accessory pulleys. With that cover removed it makes it real easy to access the AC compressor plug. I zip tied the box to the hard brake line that runs along the to[ of the frame rail next to the compressor.
On a side note, related to driveshafts...
My Mustang has a FMS (Ford Motorsports) aluminum driveshaft. It is larger diameter than a stock steel one, 4" vs 2.5" or something like that. It's held up behind a 600hp motor doing 5000rpm clutch dumps on slicks and 130mph trap speeds
Thanks for clarifying. I didn't know one way or the other. I was just speculating that it might be a risk.Someone said yesterday that you’d need resistors for the hybrid tails to avoid hyperflash- no you won’t because only the brake lights are LED. The turn signals are still incadesent.
For sure. Friday I’m going to the junk yard. They said they have a hybrid 2008 sitting in the yard so i’m gonna try and swipe the d pillar trim but the said they only have one tail light. Minimum I’ll look at the harness.Thanks for clarifying. I didn't know one way or the other. I was just speculating that it might be a risk.
Cool. It will be informative to know if the Hybrid D-pillar appliques are different from Escalade ones. If they're the same, I'd guess Escalade ones are far more commonly available than Hybrid, and would be an acceptable substitute. I have a pair, and can take measurements if necessary, for the good of the community.For sure. Friday I’m going to the junk yard. They said they have a hybrid 2008 sitting in the yard so i’m gonna try and swipe the d pillar trim but the said they only have one tail light. Minimum I’ll look at the harness.
Coolieo. I’ll ****** em and bust out the calipers.Cool. It will be informative to know if the Hybrid D-pillar appliques are different from Escalade ones. If they're the same, I'd guess Escalade ones are far more commonly available than Hybrid, and would be an acceptable substitute. I have a pair, and can take measurements if necessary, for the good of the community.
Nice!!View attachment 227931 View attachment 227932 Got my new tails installed in The Machine.
I was wondering how long it would take. Put my Fumoto on last change. +1 on filter mess. There's nothing like balancing a full-to-the-brim cup of hot motor oil while laying on your back.Did an oil change on the burb. First time with the fumoto oil change valve. Handy, clean (for the oil drain - filter change is still messy AF), but very very slow even on hot oil...
