kbuskill
NE. FL.
Okay that was on 11/20. Today I went to refill the washer fluid to stop the Master Caution warning message in the cockpit. I noticed that the “sight glass” in my catch can (16oz?) was past the halfway mark. I put this coffee can under it and was shocked to see crystal clear water flowing out and then an emulsion at the end (the oil floats to the top...). Holy moly this is crazy!
So basically I’m getting like 8-10oz of water being “caught” every month/3,000 miles. Where does this water go if I didn’t have the catch can??? Is the catch can system trapping the water from venting into atmosphere? (Am I better without it?)
Definitely NOT better off without it.
Do you do a lot of short trips around town?
What has the temperature been like in your area recently?
R3cord303
Posse In Effect
Oregon Valley
Water/condensation is caught in any container with airspace. Inside the crank case of the engine, in your axles, your catch can, etc. its part of the reason steam comes out of your tailpipe in the morning. Gotta blow all the condensation out of the muffler, the cats, etc.
In the engine the moisture in the crank case will evaporate and run thru the PCV system. Thats why you’re catching so much in the can. Also why on higher milage older vehicles you see some of that same funk on the bottom inside of the oil cap. The oil cap is the highest part of the system, so water and oil vapor collects there.
if you didnt have the catch can, those vapors would run thru the intake and out the tail pipe. Not really a big deal but i’m sure the engine will be happier with the can.
trailblazer
I drive about 3000-3100 miles a month to work and home; 130 miles round trip. I live in the great white North; it has been -15 to +32 (yesterday). I have noticed a lot more water since it has been so cold out.
I started converting them but ran out of patience lol. I’m suffering from small part wrap syndrome. ***** a PIA. It will eventually match the other stuff I wrapped. I did the big wood grain part twice tonight and didn’t like either application so I ripped it off. Twice. The area around those cutouts is done but it about killed my patience I think.
I wish we could see a video of you doing this. Not to watch your struggle, but to learn techniques in both what TO do and NOT to do.
As Ken and Allen mentioned, it's condensation from your crankcase. I never have any, but I'm in a totally different environment than you. A few months back, @CHOO CHOO posted similar catch can results and he's in PA. So, I guess it's cold enough up there that your crankcase air never gets warm enough to steam off the water, even when running the engine for so long. Also, you guys use a different blend of fuel during the winter months and that may contribute to the extra moisture as well.
The moisture itself is absolutely harmless. The oil in that air is the problem and that is why you need the catch can.
Yesterday would have been super entertaining, I got so pissed off and used every cuss word in the book, 10 times each. By the time I edited all the cussing out there would have been about 2 minutes of video, on what NOT to do. :mad:
BG1988
Water gets burned off to steam cleans your engine
wjburken
Eastern Iowa
It was almost 70* today...on Christmas....in the Midwest.....I got to wear shorts....so I washed the Tahoe and wifey's Equinox. Man there is alot of body panel surface area to wipe when washing.
I’m with you. Weather is crazy warm for this time of year. Up here in Iowa, only got to low 60’s, but it was more like a nice spring day and not Christmas. Had all the windows open while we entertained part of my wife’s family for lunch.
TVan
