kbuskill
NE. FL.
alexalex
[/QUOTE]
Wixey makes some neat digital angle finders that are pretty inexpensive. I use them in a lot of applications both at home and at work when setting up equipment.
Fully agree! I personally have a Wixey angle finder reviewed by ProductAdvisor that I am finally beginning to use, mostly to help me find new or forgotten locations of objects. It is a great tool for first time finding. If your angle finder is not self zeroing, be sure to do that, and then you are set. The Wixey is very compact and works well. It's drawback is the brightish green display on the model I have.
You’re pulling the motor at 200k? You going to rebuild it, or replace with a built 6.2? [emoji16]
I wish I was ready to replace it with a 6.0 or 6.2! It doesn't need a rebuild. Just gonna delete the AFM (already disabled in tune), refresh and re-seal it. Has a small oil pan gasket leak but since it'll be out, it'll get all new gaskets along with the lifters, oil pump, timing set, rockers, valve springs, etc. Really, the only thing I'm leaving alone is the rotating/reciprocating assembly and all the bolts except for the TTY ones.
Sam Harris
Texas
I wish I was ready to replace it with a 6.0 or 6.2! It doesn't need a rebuild. Just gonna delete the AFM (already disabled in tune), refresh and re-seal it. Has a small oil pan gasket leak but since it'll be out, it'll get all new along with the lifters, oil pump, timing set, rockers, valve springs, etc. Really, the only thing I'm leaving alone is the rotating/reciprocating assembly and all the bolts except for the TTY ones.
Niiiice.
Cdisharoon84
