St. Louis
FYI the tensioner is cheap and easy to install. I’d recommend most 2010+ owners going this route if they anticipate difficulty with the stretch-to-fit belt.
Don't forget also the older model belt when doing this, as the newer model stretch to fit will be way to short/tight to use with a tensioner pulley.
Used a old toothbrush and spread the epoxy all over as much as I could and zip tied it fingers crossed, couldn't do much for the dash the break is right on a ridge so no way to really fix it without taking it out but I dabbed some along the cracks under the center speaker cover and used a couple small pieces of popsicle stick
You should drive with it like that. The looks would be priceless.
cmatt
Got an Amazon order of fluids and parts in for the Suburban. I plan on swapping out the RSE controls tonight. Existing controls illuminate, but don’t function. Seems an entire soft drink was spilled on it. Does the new module need any programming to work or will it be PnP?
Sent from my iPad using Tapatalk
08z71bgm
Long Island, NY
Speaking of fluids I need to order front and rear axle fluid.
Anyone have the part numbers in ac delco?
Do I need any posi additives?
The transfer case fluid is atf correct?
gat0r
DFW
well crap the clear jb weld clear epoxy I used did not bind the leather and wood trim, it did bind to the dash plastic good though
so what has anyone used that worked for the leather/wood trim?
I think a guy used gorilla glue to bond the 2 together. Double check that tho.
careful w/ gorilla glue... it will probably work well... but it expands a lot
cmatt
George B
¯\_(ツ)_/¯
Oconomowoc, Wisconsin 53066
Rear entertainment module is plug and play.
SPIS
