Sparksalot
Bastrop County, Texas
I think that's a splash shield. I don't think the plastic would hold up well as an actual skid plate.
Funny you say that. I’m fabbing a light gauge piece of sheet metal to back it up right now. Not so much for rocks, but other pokey things encountered off the beaten path.
Sparksalot
I guess if you want to go through a bunch of extra work just to be more comfortable? I mean valve springs are pretty easy to do with the heads in place. I can do them in a couple of hours or so. #7 & 8 cylinders are the only two that are a bit of a reach, the others are easy.
I know it possible to change them in place. I’ve always had the heads off because I was grinding valves at the same time.
Just Fishing
Can't fix stupid
Utah
Changed the oil and then I got to work on this.View attachment 272710
I got that when i first got my hoe.
Everywhere said "auto track II fluid" in the t case.
Me: i happen to have a few bottles on hand, so i used it
Man that t case was not happy at all.
Once i put the correct atf in there, all of the issues cleared right up. :D
Just Fishing
Can't fix stupid
Utah
And i kicked the vette out of the garage again.
I need to organize a bit first, but the hoe is about to get the oil pan pulled.
I'm also scoping out some nice used engine hoists.
Found a super heavy duty one not too far away from there, but it does not fold...
Looks like you could pull an entire car with it. :eek:
All depends on the transfer case as to which fluid to use. Mine takes AutoTrac II.
St. Louis
Either @Doubeleive or @kbuskill bought a metal one with louvers stamped into it. Thought it was pretty pricey though, but looked nice.
I bought the OE steel transfer case and front differential skid plates made for the trucks or Z71s and put them on my 2012 Denali. The holes are already there.
DunzoDenali
