the_tool_man
Upstate South Carolina
Let me know how the Mini split works out for you, I have a 18k BTU window unit in the garage and have been looking at replacements that are a bit more efficient.
I can say with confidence that a mini-split is FAR superior to a window unit. You get significantly better efficiency, better control over air handling and temperature, and programmability that a window unit can't come close to.
Installation is pretty easy. The outside part sits on a slab, or a bracket on the wall. The inside part hangs on the wall on a bracket, similar to a microwave oven. You need a 3" diameter hole for the line set to pass through, and a single circuit to power the whole thing.
I've had a 3/4t mini-split in my bonus room for 12 years with zero issues. I spent uncle Joe's stimulus check on a 1t unit for my workshop. It's on a pallet in my garage waiting for a free/non-rainy weekend to install it. This will replace a very old, loud and inefficient window unit that I can't wait to get rid of!
Don't wait. Do it.
Just Fishing
Can't fix stupid
Utah
A little payback today for all the time and money invested.
Making me want that lift...
it would fix that ground clearance issue i have with the hoe
This 6" one was too short to bother with the mesh, so it's all heat shrink:
img_5801-jpg.277625
It runs from the engine block (at the bolt for the power steering pump bracket) to the frame (under an engine mount bolt):
img_5802-jpg.277626
Copied the factory alternator-to-main fuse cable:
img_5805-jpg.277627
With very minor trimming of the mount on the firewall, the lug fit fine:
img_5807-jpg.277628
Followed the original routing and was even able to slip the terminal boot on after a little squirt of B'laster:
img_5808-jpg.277629
I want to replace the battery terminals with some marine post-to-stud adapters. I'll make the positive lead from the battery to the main fuse when I get those terminals. I'd like to make a starter wire as well.
Giving me ideas, as I try and find things to keep my self entertained while the machine shop takes it's sweet sweet time...
Too late, but i love this stuff for wrapping wires. Amazon.com: Heatshield Products (204011) 3/8" ID x 10' Hot Rod Sleeve Roll: Automotive
Lots of different sizes, and it looks great with a little shrink tubing to seal the ends.
In the old vette, the dashboard is a big piece of Styrofoam, I found a few somewhat unfused wires that go within inches of that piece of foam.
few years back; I had the dashboard headlight switch go out, started a mini fire.
Once i pulled the dash in order to fix it i saw how bad it could have been.
One inch away from that big piece of white Styrofoam!
then the problem that fiberglass is technically flammable. :banghead:
:jester:
Yup. every wire i could get to, got wrapped with that heatshield stuff.
:waytogo:
And, maybe tomorrow I'll harass the machine shop again...
if they don't think they will have it done by this weekend, I'm thinking about ordering this: Total Seal Piston Rings 8910 Total Seal Piston Ring Squaring Tools | Summit Racing
:jester:
:waytogo:
Thanks for that one but this time I AM only adding it to my list, not ordering it by mistake.
briwesric
