You don't get rust in Weezyana? Figured with all that humidity
Mine looked clean like that when I got it in August 2018. Still does for the most part, but some of that black coating on the frame is getting some light brown areas near the edges and corners. I think it's from driving in the **** they put down when it snows.
Humidity is mostly just water. Salt is the killer. Actually, those that live on the coast get some rust, but its not like the rockers and wheel arches rotting out within the first ten years like the areas where the roads are salted.
So much real-estate to install a wideband O2.
Me: one of these to a part that i won't name is sounding very tempting right now.
I don't even know how to tune with what I have now! I do have the Pro Features hardware for my MPVI2, but I don't know if they're even supporting it in the software yet. I do want a wideband, though. One for each bank, if possible. I might could put them where the downstream O2 sensors are since they're just there to plug the holes. Or put the regular upstream ones in the downstream spots and the widebands in the upstream spots? It only like 6-8 inches of difference.
Got rockers installed last night!
Modified the valve covers slightly.
Looked to be a tight fit in there, got the idea from one of the Q&A answers on summit racing.
All this work to perfect so many minute details, yet you're gonna roll with the old style rocker cover that might very well contribute to oil consumption...
:Nonono:
Just Fishing
Can't fix stupid
Utah
:Nonono:
I actually looked at the current valve cover and it looks identical, am i looking at the wrong one?
Eta,
Looked again at the one i had saved.
Dorman 264-969
Looks real close, but the inlet is slightly different....
Just Fishing
Can't fix stupid
Utah
I just learned how to use a wideband with out pro features!
You can add it in hp tuners to a laptop via usb to serial adapter.
Apparently you can also log your fueling map and it will make corrections that you can paste into your actual fueling map!
My ebl flash does that, but it also writes it to the tune file for you.
I wish hp tuners was that slick.
I still have a loooong ways to go, but things are already making more sense.
Eta, you can replace your narrow band with them and wire a harness from the little processor deal to the orignal harness.
But the recommended is to install a **** just for the wideband.
Goat rope garage on youtube.
I really need to be in the mood for it tho.
markstaho
