gooffeyguy
Tom
Reason I asked is because E85 will clean up carbon from combustion chambers, so curious if it would've cleaned those up
Looks like it was laying next to the Titanic! I'm always on the hunt for new 41-985s!
Yes & NoDid you ever run E85 with those funky plugs?
You think the high flow pump was faulty? Not putting out enough pressure?Today is the day.
pulling crossmember, front axle, Oil Pan, pickup tube, and windage tray.
Hoping i can clearly see damage and it's just bearings.
If all looks good, then the engine is getting pulled.
I'm pretty sure the issue was the highflow pump.
If yes, then it's probably a rod bearing since it's last to get lubed.
crossing fingers.![]()
That's a thing? That sux.He ran the sump dry on startup from too much flow…
