Mickey_7106
Bay Area
can anyone please let me know what the torque specs for the transmission pan are? 6L80/90 please
St. Louis
Just got done doing an engine oil and filter change.
I think my oil cooler line adapter plate is still leaking a bit. I had a bit of oil residue on the filter and bottom edge of pan. I think it's coming from that O-ring plug that faces the rear. I replaced the gasket last year and had to unbolt the front U-joint and let the driveshaft hang to get the clearance I needed to get to it. Looks like I'll have to do that again and remove that line adapter block in order to get an allen/hex wrench on that to remove it. There's not enough room with it still attached to the pan, the bellhousing gets in the way. Gonna save that for after I get my QuickJack. Did the oil change with the front wheels pulled up on ramps.
Just Fishing
Can't fix stupid
Utah
Installed new OEM seat foam on my driver side butt.
Surprised to see the new foam was a dark grey almost black.
I thought the seller pulled a fast one for a min, but my butt is very happy now. :beer:
Mickey_7106
Bay Area
Anyone drill holes on the transmission dip stick to check oil level? Now that i have fresh oil, I'm having a hard time checking the level after topping off
Just Fishing
Can't fix stupid
Utah
Picture of the fresh seat foam installed!
Used a steamer to try and get the wrinkles out of the side bolster.
It's getting there it got it pretty smooth, but I think the sun will help too.
I sort of wanted to replace the leather cover due to the patch on the side but opted to save the $$ since it's not too bad.
N8daGr8
