RooTBeeRthe1st
Finally put the lubelocker gasket on the 14bolt to replace the new and failed felpro I had on there.
Topped it off with amsoil.
No puddles under it this morning.
Needs a wash and check the oil level before I put a few hundred miles on it this weekend.
Drwinlied
Installed cabin air filter kit yes I needed it simple procedure.
This reminds me I need to help my stepdaughter replace hers in her mazda3. Fcker reeks and has since we bought it (very used )
Why do aftermarket header/bolts loosen but not factory?
Things that make you go hmmm
Because they have a smaller bolt head surface area so less contact to keep it in place, less metal coverage overall so more prone to heat/cold expansion, they make locking ones I have seen them or pictures of them anyway
St. Louis
I've used locking ones before with aftermarket headers, just didn't know why OE bolts didn't loosen. Them having bigger heads make sense.
I installed Stage8 one's that have a tab then a C clip that holds the tab into position, but they're really a pain in the ass and hope you don't lose the C clip.
I then switched to some Breslin Split Locks which I like and are easier. The threaded part is split and there is a set screw in the center of the head that spreads the split part slightly after installing. I think the patent is expired now and other brands make them, like Summit, Mr Gasket, and Percy's.
St. Louis
Planning on changing out the front and rear differential fluid. Manual says they both take synthetic 75w90 gear oil. Says nothing about limited slip modifier so I was going to get the Mobil Delvac with no additive.
Also doesn't give me a capacity and researching online I've found 2.75qts rear and 1.8qts front. Is this about right, even for the Denali with AWD? I was going to buy 5qts. Will that be enough or way too much?
briwesric
