found a tree to it for another model but will be the same just choose right car
Work around procedure with a TECH2 to reset the transmission oil life monitor.
1. On the TECH2, select Diagnostics.
2. 2009
3. Passenger Car
4. Cadillac
5. K
6. Powertrain
7. TCM
8. Module Setup
9. Reset Transmission Oil Life
10. Type 100%
11. Perform Reset
j91z28d1
2. 2009
3. Passenger Car
4. Cadillac
5. K
6. Powertrain
7. TCM
8. Module Setup
10. Type 100%
11. Perform Reset
yeah, just took a look. no option for module setup under tcm. Just the trans daps relearn stuff it says to do after a rebuild. I'll leave that alone.
probably a hybrid thing. I looked everywhere else I could think of and nothing.
so that doesn't mean the dongle can't do it, just that I can't find it on this thing.
89Suburban
Bull in the china shop
SE PA
Spent my New Years Eve at the shop with my truck. Wanted to use the flat floor to get some vehicle height and camber measurements and rotate my tires and inspect things whilst doing so. Finally found that rattle that has been driving me nuts for months. At least I hope so anyway. I have been under the rear of this thing several times trying to find it. Don't know how I missed it. Hoping I have a nut that fit's it in my "Tahoe" fasteners bucket to fix it today.
Fless
Super Moderator
Elev 5,280
View attachment 417732View attachment 417733
"...driving me nuts..." I see what you did there... ;)
89Suburban
SE PA
Thinking about lowering the rear another inch or 2. And get rid of this stupid Chevy lean sh*t. So I took some measurements at: Front fenders, running boards, rear fenders, rear bumper lip.
Then camber measurements are whacked, no way this floor is level flat, probably sloped flat. I zero'd out the camber gauge on the r/r wheel and worked my way around. Usually I zero it out on each rear wheel and then measure the fronts.
And I measured rear axle to frame clearances at the bump stop mounts.
avalonandl
Troy, MICH & Naples, FL
Did you find the bolt and washers
St. Louis
1/8"-1/4" isn't much of a "Chevy lean", If I'm reading your chicken scratch right, lol
jeffs2021
