93blkongreenpro
Ordered 2" drop springs from Tony. Come on the 20th of next month. I'll have a day and a half to replace all my front suspension, put rear springs and shocks on ( undecided on helper bags yet), the new intake manifold ( broke the pcv nipple), and brake light switch bc my cruise control knocks off when I hit a bump.
Then alignment the 21st. I think it's doable.
And if I have time, get the windshield tinted.
Maybe polish and wax, but that may be pushing it.
Sent from my iPad using Tapatalk
ISU-152
Why would you need helper bags with a drop?
CHOO CHOO
BackPagePhil
Manheim, Pa
Helper bags are cheap and easy to install especially if you are already taking stuff apart. I love having them even if i dont use them much. Nice to know i can throw a heavy amount of stuff in or tow a big trailer if i need too
Sent from my VS985 4G using Tapatalk
Fosscore
X2 on the bags while you have everything apart. Less than $100 and ready if you need them.
Jason_S
Can you upgrade your injectors and pump to bigger components that are ethanol compatable?
You'd make a bunch more power and be more resistant to knock on the E.
Makes a huge difference on the EVOs. If I switched to E85 right now I'd net 60-80 more WHP and be real close to 500 Mustang Dyno at that point. Unfortunately the closest station to my house is 60 miles away so it's not very convenient :(
At this point, he would also need a retune (obviously), but with that tune he will probably need the alcohol sensor re-enabled and the ethanol maps added back in. he will not 'need' to fuel up solely at e-85 stations IF everything is added back in correctly. His ECU will be able to recognize the alcohol content of the fuel and adjust for that content. A pain in the hind end, but do-able and can get pricey if paying someone else to do that work. Depends on how serious you are about that extra HP, but the dollar per HP ratio will be steep.
950410
x3 on the bags. Have them on my lowered TBSS that has seen a ton of towing miles. No issues at all.
dross99_si
SE Florida
Yeah it will be back to true flexfuel.
So need for bigger pump or injectors though? Do the stock parts flow enough? So basically no mechanical modifications needed, just tuning related changes?
Not sure it's worth it to spend the dough if you don't have E85 close by so you can run it daily.
Would be cool to unlock that extra power though.
tswelsh
