Trx_Tahoe
Installed Alla Lighting LED Fog 5202 , switched from DDM 5202.
Although I like some of the DDM product line, these 5202 turned out to be a disappointment. So, I took a chance on these Alla Lighting 5205. I like that they have a more defined cutoff .....See Pics
I had to cut a little of the plastic clip for them to clip on correctly, but did not have any issues with the Oring as I did the DDM 5202.
DDM (L) - Alla Lighting  (R) 000.jpg DDM (L) -Alla Lighting (R) 001.jpg Alla Lighting 002.jpg Alla Lighting 0003.jpg
Looks like I'll be adjusting my headlight on the right looks a bit "high" on this last pic....
Both Alla Lighting LED 5202
HoS
That is a level ground? How high does your lamp sit?
Sent from my SAMSUNG-SM-G935A using Tapatalk
Trx_Tahoe
Well it's was the garage floor, so I would venture to say yes.... I'm not sure how high the fogs should be from the ground. Then the main headlights from the ground as well...
Sent from my LG-H910 using Tapatalk
lonestar24
That's neat and clean. Link to what you purchased?
Sent from my SM-G935P using Tapatalk
You can reuse the existing plug cover or get the one with the USB insignia on it. The USB plug part # is 20944422, the cover is 20983937. Only other things you need is a cigarette lighter usb adapter and usb male to mini usb male cable (happens to be the same cable to recharge PS3 controllers).
http://www.ebay.com/itm/NEW-GM-USB-...ash=item2587b1232f:g:lucAAOxyNmZTkMa3&vxp=mtr
Safetypup
