What do I need
Lentsnh2012
What do I need to lower my Yukon XL Denali 3" in the front and 3" in the back. Can I do it without pulling parts out or welding
Not trying to be rude, but this topic has been talked about already- multiple times. Try and search before asking.
However, to be nice and have helpful posts, DJM lower control arms and a 4" drop coil with a 1" spacer and new rear shocks should give you your desired stance.
Not sure what you meant by "pulling parts" but you'll have to install new coils and whatnot to get everything correct and not ghetto-fabbed.
Z
zieglerj-pdm-specialist
in 100 degree sandbox
honestly sorry
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
do you want to keep the autoride?
3/3 you will have major rake here is what id do
you can do this kit 2/3-4 and keeps autoride
http://www.tbssowners.com/store/index.php?act=viewProd&productId=86
now if you want to go more you can do my custom 3/5-6 kit and excellent ride. I designed these rear springs
http://www.tbssowners.com/store/index.php?act=viewProd&productId=88
any questions just ask
Z
Thank you so much for BEING HELP FULL when someone ask's a question. WE NEED MORE PEOPLE LIKE YOU ON HERE WHO ARE OUT TO HELP AND NOT TO CRITICIZE A GUY FOR NOT KNOWING. I mean it thanks allot. I will be ordering that kit. Being a 7 on the mechanic scale, I've changed wheel bearings I repaired the auto ride,alternators,water pump, oxygen sensors and a transmission do you think I could install this package on my own Thanks again and Take Care.
---------- Post added at 02:01 AM ---------- Previous post was at 01:56 AM ----------
Its really nice to type in your problem into a forum and get your answer with not having to fumble around and end up how to lower the front of an Acura integra. Thats what was nice about this. Thanks
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
been here for years and i dont read out of a book i actually install these kits also
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
you dotn need a spring compressor.
david76008
Tony, what are the major tools needed? I got a air tools, but no plasma.
I should be able to knock it out in my driveway with some help?
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
i use a sawzall to cut off rear bracket. if you have airtools you are fine. socket/wrench/drill
EdwardsD
