donjetman
- Joined
- Oct 22, 2018
- Posts
- 1,682
- Reaction score
- 2,961
x2, Mine is the as Joseph, w/163K miles nowMy 6.2 with 145k on it has ~50psi when cold. When warm, 40+ psi while driving at 1500 or more rpms, and ~20psi at idle.
Yes it does. When I had low oil pressure in my 2012, it turned out to be the screen.yowza I thought my ~17 at hot idle was low. I would also get a reader of some sort. Perhaps just a cheapo bluetooth one from amazon, but see what the oil pressure truly is. Does that motor suffer the oil pressure sensor screen clog issue?
Yeah I was curious, because I scoured the interwebz trying to find a replacement sender and screen on my LY6....but I guess the iron blocks didnt do a screen. Who knew?Yes it does. When I had low oil pressure in my 2012, it turned out to be the screen.
For the original poster, I'd replace the oil sender and the filter screen below it before you go to the trouble of pulling the camshaft. It's super common for those things to clog up over time and drop your pressure readings artificially. My gauge looked and behaved just like you're describing, and eventually dipped low enough to trigger the low oil pressure warning.
Read it 3 times and missed it. ADHD is a *****.OP said he replaced the oil sender and screen, fyi
Ahh afm VS non afm.. Not iron VS aluminum. Got it.Iron blocks got it. My LMG is an iron block.
I think it was just on AFM engines. Your LY6 doesn't have AFM.
