What elastic bands to choose?
Tahoe rus
Moscow
Your council is necessary. It is a lot of variants of spare parts, Bushings of what firm is better, Energy Suspension, Moog, GM, AcDelco and why?
Narco
Atlanta
??? you might want to elbaorate on what exactly you are asking
TigerEyz3
Slow and Steady
TN
Given that you're in Moscow (assuming capital city) and deal with extreme cold, it might be a different situation than what we deal with here in the US. That said, the following explanation, may or may not help...
Polyurethane bushings generally give a more responsive ride as they are more rigid than rubber bushings. The extra rigidity also transmits more vibrations to the driver/cabin than rubber. Both are good options and have their place. Which is better depends on what you are trying to accomplish.
retorq
Kingman AZ
Poly won't break down with exposure to grease and oil.
Poly will squeak/bind if it's not lubed properly upon assembly.
Poly deflects less the rubber so stuff like hard cornering will be predictable.
Queen_313
