What fluids are you running?
MichaelSE
2010 2500
Tucson
I'm about to swap out all my drivetrain fluids and want to know what others have had success with. Here's what I'm thinking:
Front diff: Lucas 80W-90
Rear diff: Lucas 75W-90
T-case: ACDelco Dex VI
ATF: ACDelco Dex VI
Look good? Not looking forward to that ATF swap because of that exhaust. What fluids is everyone else running?
MichaelSE
MichaelSE
2010 2500
Tucson
I use Mobil 1 for oil, I didn't realize that they made Dex VI also. I'll definitely look into that for the trans and t-case.
MichaelSE
MichaelSE
2010 2500
Tucson
The tranny fluid isn't fully synthetic.....it's a synthetic blend.
Does this mean it can't be mixed with the synthetic ACDelco Dex VI that's in my transmission now? I plan to do a drain and fill, not a full flush.
benski
You shouldn't have any problems with a little bit of conventional ATF left in your tranny. Of course, the ratio of synthetic to conventional will determine the operating parameters of the ATF that is actually running around in your tranny.
AZSCTACO
Phoenix, AZ
I'm almost positive ACDELCO doesn't make a full synthetic Dextron VI ATF fluid. I'm pretty sure it's a blend as well. I've been doing drain and fills with Mobil Dextron VI over the past couple of years and no issues at all mixing them.
MichaelSE
MichaelSE
2010 2500
Tucson
Here's what I was looking at - someone on Amazon asked whether it was synthetic and someone quoted the back of the bottle as "full synthetic."
https://www.amazon.com/forum/-/Tx2UTT3LK0HNJ4T/-/ref=ask_dp_lsw_al_hza?asin=B01EKMGG92
Still not sure though since I have found a few references on forums that say it is a blend. I may call up ACDelco just to find out from the source.
HUMBL57
AC Guru
Phoenix, AZ
Dex VI is Dex VI... Full synthetic or not, you're not going to hurt anything as long as it's clean fluid and filled to the proper level
Roscoe2352
