Standard eBay projectors. They're known for having a bad light pattern and overall poor light output. Most people find that they can see way better with new/clear OEM headlight assemblies. Check their aim on a level surface about 25' from a wall or garage door and go from there. Brighter bulbs, whether they be HID or LED can help some, but then you're just trying to push through a poor projector lens. You're also limited to stock or nearly-stock wattage because the housings and/or projector can melt if you try higher-wattage bulbs.
