What is this leaking?
kcb37
Nothing.
That is the evap canister. Nothing but air and gas vapor. (charcoal in the canister)
More then likely just crud on top.
Wipe if off, should stay clean for awhile.
kcb37
Does it smell like gas?
If so the canister is probably cracked. If you have a vacuum pump you can take it out, plug each opening and pull a vacuum on it, should hold.
Lines should be just the 3 on top.
If it's oil, I vote for Power steering.
When you fill it up, do you let the pump shut off then fill it up the filler neck? That will cause liquid gas instead of vapor to gather in the canister and saturate it.
livingez_123
Sandy, OR
Looks like power steering fluid to me. By the looks of the PS lines that could be wet.
tfol
