What keys to use???
bdesr32
Torrance
Do the ford keys allow the spring load on the torsion bars to stay the same with lifting. I dont want to crank the keys cause I don't want a stiffer ride. Just a mild lift, stock ride quality. Anyone use the suspension maxx keys? What are your guys' recommendations for this keys and spacers......also with 33s would you guys suggest changing the gears from stock, or does it not make a noticeable difference.
Thanks
polobuds
East Bay, CA
changing gears is an expensive proposition, one that is not really needed if you want to put 33s on. If you do a lot of offroading, it may be worth it.
check out this link about gear ratios (scroll down half way);
http://www.4wheelonline.com/superlift_tiresize.htm
I have 33s and stock 3.73 gears
Depending on tire tread depth and tire weight, you'll feel it when accelerating and you'll see it in your speedometer if it's not recalibrated. Mine takes a little more to get going and my speedometer is off by 2-6 mph
brucebruce45
Crank is crank, doesn't matter if it's from ford keys, reeadylift, suspension crapp or what. Get ford keys and longer shocks an be done
zaathur
im running ford keys paid $60 each for them in stock at ford and installed longer rancho shocks in front rides good
chevy_man
Great Falls
The only reason cranking raises the front is through more pre-load on the springs. Any crank = rougher ride.
brucebruce45
Cranking doesn't put more preload on the tb's. It simply turns the lower control arm down more. A rough ride comes from shocks too short or riding on the droop stops
zaathur
i have my ford keys and 2 month old 2in. lift rancho shocks for sale if your still looking for some
Malden11b
