What motor oil do you use?
FoxDen
SoDak
Mobil 1 5-30. Run it in every vehicle I own. 1997 Suburban has 230k on it. Have ran Mobil 1 5w-30 for 10 years with no problems.
I've got 260k miles...using 5/30 Mobil Super High Mileage. With this many miles, I couldn't justify the synthetic cost when I'm doing oil changes every 3k miles. Nope, never waited for the oil change message.
Sent from my SM-G925P using Tapatalk
hec.deli
137k AMSOIL XL 5W-30 Synthetic with Mobil 1 Extended Performance Oil Filter (through research I've picked it out as the most fitting and highest performing oil filters out there) every 6k miles of course I could go 10k but I don't like the sound of changing it every 10... If I were to go any other route I would definitely stick with Mobil 1 5w30 for sure.
1992rs
OR
Redline 5W-30 and a k&n filter. Change about every 5k miles and comes out pretty damn clean. Id use castrol if I had to go to a local auto store.
Chizzychase
Valvoline 5w30 high Milage synthetic blend with a generic auto part store filter. Just as long as you keep up with your oil changes it shouldn't matter too much
aces-n-eights
Alaska
I've had good luck bringing my own oil and filter to an oil change place and they do the change. They usually charge me around $20 for the labor. Sometimes that's worth it to me and other times i change it in my garage...
sumo
dn ʇǝƃ ʇuɐɔ & llǝɟ ı
rhode island
I stopped buying the Expensive stuff. I started using the the free stuff. I work at a deanship, so i get 5w-30 synthetic blend, Access to a lift and usually end up changing my oil about 50%
jangel
