lumberjack890
- Joined
- Mar 27, 2020
- Posts
- 67
- Reaction score
- 13
Just want to get an idea of what most people use
My own research shows that K&N is superior numbers wise to Wix, M1, Fram and ACDelco. The oil pressure is higher on my motor running the K&N compared with the M1 EP filter and the K&N filters down further particles wise, 10 microns compared to 30.
You won't hurt your engine by running ANY of them. We run the K&N because we like the 1" nut welded to the bottom for removal, helps my daughters and I when changing the oil.
The higher quality filters may have less paper fibers clog up the screen under the oil pressure sensor over time which can affect the AFM system.
I wondered about that too.I was always curious about a longer filter, but having the nut on the bottom would mostly take care of that.
Interesting that the k&n filter finer, plus has higher oil pressure.
Sent from my SM-N960U using Tapatalk
