what oil to run
Norton
MI
would ams oil racing 10w-30 dominator be good to run on a flat tappet cam motor
N
Norton
MI
what oil to run on a flat tappet cam
would Ams oil do the trick? hoping to get it back on the road been 3 1/2 years since she has seen the road.
ccapehartusarmyINF.(ret)
Gilbert AZ
royal purple or joe gibbs
---------- Post added at 08:51 AM ---------- Previous post was at 08:46 AM ----------
also running a full synthetic like royal or joe gibbs will find any oil leaks you have in the motor
SunlitComet
OBS Jedi-Do Good
unknown at this time.
First, use the oil that the manufacturer set which is typically 5w-30 unless in very hot or very cold environments.
Second, synthetics do help you find oil leaks.
SunlitComet
OBS Jedi-Do Good
BigJcar
