What size tires are best for these 22's?
jeffreycip
Clovis, CA
I have a stock 2007 2wd Yukon w/ 17's. I am purchasing a set of 22x9.5 wheels with an offset of 30. Whats the best tire match to keep them under the fender and minimize rubbing. Also, Its unlikely that I will ever lower the Yukon.
Thanks in advance......
DTAILS
BUMP .........
I'm interested as well. I feel 22" and a 2" / 3" drop coming in the near future.
AZSCTACO
Phoenix, AZ
If you never plan on dropping then 305/45/22. It will fill the wheel well nicely. I had the same set up with the same wheel offset.
If you plan on dropping....then 305/40/22.
Sweet_N_Low
305/45/22 will still work with 2/3-4 drop, that's what Tony (Norcal SS) recommended
walkerheartsfield
