What thermostat to run??
95TwinTT
Minnesota
There seem to be a lot of guys running lower temp stats here. I’m not sure what the reason would be in the winter, but I would like to point out that oil does not lubricate as well at lower temperatures.
I once bought a new chev pickup truck that came from the factory with a piece of casting speered through the thermostat, holding it open.
I complained over and over again to the dealer about the lack of heat. Because it was a diesel engine, they kept telling me that diesels, run colder than gas engines.
I would have gotten into it myself, except the truck was under warrantee and I figured it was their job. Plus I was busy working 70 hours a week at my job.
Finally after getting back from a trip to Chicago during frigid temps, I stopped back at the dealer to insist they check the thermostat. This was visit number six for lack of heat.
I came back the next day to pickup the truck and found it in the bay with the engine removed. Running cold had caused all the cylinders to wear in a “bell” shape. (much wider at the bottom)
Chevrolet gave me a new engine when they could have just checked the stat in the first place.
You guys do what you want, but just know that a cold engine is not being lubricated as well as it should be…………………..:)
TIM Z
DMAX Power
Navarre Ohio
Great point and advice.
If you have to drive your vehicle year round, do you self a favor and either leave the stat stock or have 2 thermostats to use for warm and cold weather.
JennaBear
Resident Ninja
Supporting Vendor
San Diego, CA
X2
These engines need to run at higher temps to burn off condensation in the oil as well.
Brandon X
Michigan
If I lived down south id run a lower temp, but it was 6 degrees fahrenheit today, soooooo...
mdiacont322
Senior Member
What does a colder thermostat do anyway? does it increase power?
Champ74
