What to Expect "DJM Hardware Kit"
Travieso
Boooooooost !
Los Skandeles, CA
Hey everyone about to get ready to install my DJM Hardware kit and TB 5.5 Coil For those of you who have experience installing this set up any pointers/tips/ etc that would ease my installation process, i have access to lift so that wont be a problem anything else i should know of ?
Alex33
It's actually pretty straight forward. I did mine in the garage w/ a jack and jack stands. The only issue I had was that my OE bolts were too short and I had to get a couple new longer ones (grade 8 zinc coated ftw!). Once you've unbolted the lower RTA and slid in the relocation bracket, you'll have to tilt the axle to get the lower RTA in the new hole. Other than that it's not too bad.
1. Support axle
2. Unbolt lower shock bolts
3. Remove old springs
4. Unbolt lower RTA
5. Install bracket
6. Bolt in bracket
7. Bolt in lower RTA
8. Install new springs
9. Bolt in lower shock bolts
Tahoewhat
Ballin' on a Budget
TX
You make tilting the axle sound so easy. lol. Mine was a pita. But i have mcgauhy's relocation, not sure its much different all same concept. But if you have a lift, you are already done w/ the hard part. Much, much easier than crawling on the floor.
but bascically what alex posted is it. Not much to it.
Alex33
HAHA, you're right Mike. Tilting the axle takes a little bit of "motivation" but it's not too bad.
Travieso
Travieso
Boooooooost !
Los Skandeles, CA
well, the kit says i need to drill a hole for the trailing arm to clear
here's what it says
The d-bushing on the driver side must be moved over on the frame about
2” (Fig #4). There is a hole already in the pad. Line up and drill the second
hole then bolt on with 3/8” x 1“ bolts (Fig #5).
http://www.djmsuspension.com/Instruction PDF 0908/Kits/RK2000.pdf
have any of you done this ?
also would i need a panhard bar ?spohn ?
Alex33
The adj panhard is nice to have but I hear it's not necessary. I like my Spohn.
Edit: I get it travieso, on the McG kit that hole is pre-drilled from the manufacturer so Mike and I didn't have to drill it. Drilling the hole in the bracket shouldn't be too bad. You want it there to keep the bracket from moving w/o the axle.
Tahoewhat
Ballin' on a Budget
TX
ha ha.. i knew it. I knew it wasnt easy.. ha ha
Adj. is nice, mine wasnt too far off actually from being lowered. I didnt notice it do anything else though. Not necessary at all. I had my stock one on for awhile.
and didnt understand the drill hole thing either until i clicked the instructions. If im understand right, your drilling a hole b/c you have to move the sway bar over about an inch or so. I just eyeballed it and drilled. Its not bad to do, just make sure you have a good drill bit and you will be fine. Moving the sway over b/c it will hit the panhard bracket on the right side. (passenger side)
But i could be completely wrong on what your asking. I read alex's, but still dont get it. I guess b/c i didnt drill anything but the sway bar bracket.
Travieso
Travieso
Boooooooost !
Los Skandeles, CA
i already have a 3/5 drop with my DJM coils but with out the hardware kit, so im not in no rush to do it, but eventually i will just wanted to look into it with our rushing stuff... Im loosing my patience though..
