Brewcity
Hey guys...new to the 5.3, and need a tune up (106,000). I have been searching for about 3 days now, and need to know what type of spark plug I need for my 2001 5.3? There is a lot of conflicting reports.
Some say A/C Delco Platinum..others say ACDelco 41-110 Professional Iridium (gapped at .040), some say get the NGK (dont know the part number for these)...which make the A/C Delco plugs. VERY confusing.
A/C Delco's website says Platinum 41-962. If platinum, is the gap at .060 or .040?
Can someone please let me know what spark plug I need, the gap, and a part number please?
Also...is Iridium really a better choice? Does it help these older 5.3 engines to run them? I read that it makes the 5.3 engine idle and run rougher.
Should I just stick to stock...or is this now what GM says IS stock? SOOOOO confused.
Thanks SOOOOO much for the help! I truly appreciate it.
---------- Post added at 10:17 AM ---------- Previous post was at 09:09 AM ----------
Well guys...I just found this bulletin from A/C Delco, so looks like I am going with the Platinum ones (gapped at .040) for my 2001 5.3L:
ACDelco announces that 2006 and older, as well as some 2007, spark plug service applications covered by the iridium spark plug 41-110 have moved to the platinum plug 41-962. For the older model years, GM used a double platinum spark plug in production, and these older applications are to be serviced with the double platinum plug 41-962. 2007 and newer applications used iridium plugs in production and service requirements will remain assigned to the iridium plug 41-110. Both plugs meet original equipment specifications for the applications designated".
I hope this helps anyone that was as confused as I was with all of this.
