What upper control arms to buy???
LOWHOE775
Sparks,Nevada
When you start getting pretty low the factory upper arms don't have enough adjustment to keep the front wheels straight up and down so you could end up with some negative camber,,,, like this looking from the front of vehicle:
The offset bushings for the front upper a-arms will push the upper balljoint outward and will make it align more like this:
Mike
Is there a direct link on where I can find this bushing kit would rather press old ones out and press new ones in. Is there a how to on this forum about this anyone know thanks
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
BELLTECH 4957 is bushing kit
or i have the new djm upper a arms which are longer to fix balljoint/alignment issues and inlcudes new balljoints and new inner bushings for $265 shipped
LOWHOE775
Sparks,Nevada
Thanks, another question would those arms better serve the purpose if I want to unscrew my torsion keys to the max? I have the djm lowering keys. Or will the bushings be about the same degrees that gets pushed outwards.
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
the a arms i have another set that gives more positive camber if needed. if your truck has oem arms and balljoints are old id do the uppers
WashFarm
