bowtiegurl
I have a 2007 GMC Yukon 5.3 liter, 4wd, 4L60e transmission that the clutches are welded together. Cooked. What other vehicles and years have the same transmission as my Yukon @NickTransmissions ?
You'll be limited to 2007-2008 4WD 4L60Es...Anything earlier will not have the TSS and anything 2009+ will have a completely different electronic command and control framework.I have a 2007 GMC Yukon 5.3 liter, 4wd, 4L60e transmission that the clutches are welded together. Cooked. What other vehicles and years have the same transmission as my Yukon @NickTransmissions ?
Do you know what 2007-2008 vehicles will work?You'll be limited to 2007-2008 4WD 4L60Es...Anything earlier will not have the TSS and anything 2009+ will have a completely different electronic command and control framework.
Any 07-08 GM truck or suv equipped with an LS pattern V8 engine.Do you know what 2007-2008 vehicles will work?
Thank you!Any 07-08 GM truck or suv equipped with an LS pattern V8 engine.
My '07 Escalade 6.2 has the 6L80 6 speed.Any 2007-2008 Tahoe, Yukon, Sierra, Silverado with the 5.3L should be basically the same, I would think the 4.8 would also have the same transmission. Apparently the 6.2L got the new (6L80) 6 speed.
I'm having a heck of a time finding a transmission. So the 2009 Silverado & Sierra transmissions will bolt right up to my 07 Yukon?Early 2009 Silverado and Sierra pickups with the 4.8 or 5.3 engine used the 4L60 as well. The 6.0s had the 4L70 Supermatic and the 6.2s and later Crew Cabs got the 6L80.
