I bought a 2010 Yukon SLT 4WD (with SLT-2) a couple a weeks ago and I'm trying to figure out the options I have. Specifically want to know the axle ratio.
When I looked at the RPO Code it shows GU4 (3.08 ratio).
It also has the RPO code Z82 (HD Trailering Equipment).
In the 2010 Yukon brochure, it states the following:
Heavy-Duty Trailering Package - Includes auxiliary external transmission oil cooler and external engine oil cooler. Includes 3.42 rear axle ratio and requires Vortec 5.3L V-8 FlexFuel engine with Active Fuel Management (AFM) on Yukon models. Not available on 3/4-ton XL models.
So which do I have 3.08 or 3.42? Is there another way to determine the gear ratio?
I tow a travel trailer so I'm trying to determine if I need to put in a lower gear ratio.
One other question... If I replace the gears in the rear end, do the gears in the front need to be replaced as well?
Thanks,
Joe
Thanks,
Joe
