So I checked everything finally....
engine gets to temp as it should.
Blower works as it should.
the hoses going through firewall - on is very hot the other is even more than very hot.
All of that says the water pump and thermostat are fine, correct? With that in mind do I still need to try and restrict the little hose from radiator to reservoir? Im thinking no but I defer to you guys.
As for the blend door actuator...just want to be clear the issue is the same temperature or lack of warm temperature from everywhere....its not an issue of cold on one side hot on the other nor an issue of switching back and forth between hot and cold the issue is just barely lukewarm air from all vents....
Could still be blend door actuator?
If so, I think theres more than one or no, and if there is how do I know which one to replace?
I dont have the funds currently to be trial and error with parts but the cold weather is here and I need heat lol
Thanks
EDIT - just watched a video...there's one actuator and its under glovebox?
Is that my next move to replace or is there any more tests I can do?
