What's Wrong With Your Yukon/Tahoe Today? ...And How Long Has This Been Happening?
Updated it the same night, didn't help.
Might want to try logging out, disconnect vehicle battery ground, leave disconnected for a couple minutes and then try again
stupid cars running on software made for phones now, every once in a while you gotta reset it for a multitude of issue's
otherwise some spotify related fixes here
Saltydog
So I just noticed the rear suspension is making crunching noise when going over speed bumps. Very annoying, not a hug deal but on a rig this expensive that should not be an issue.
JGinLA
Lower Alabama
You're better than Google.
JGinLA
Lower Alabama
I think I cleared the cache that same night but even if I did the problem remained. Here's what I did today, not sure what made the difference. Hooked up battery maintainer so I didn't have to run engine. Told Google assistant to play Procol Harum, bar appeared like it was loading. Assistant says "Something went wrong." Then I tapped album cover. Song played fine and started another song. Told assistant to play another band and she did it correctly. Much thanks.
I think I cleared the cache that same night but even I did the problem remained. Here's what I did today, not sure what made the difference. Hooked up battery maintainer so I didn't have to run engine. Told Google assistant to play Procol Harum, bar appeared like it was loading. Assistant says "Something went wrong." Then I tapped album cover. Song played fine and started another song. Told assistant to play another band and she did it correctly. Much thanks.
updates tend to break things sometimes that otherwise worked fine previously or it goes other way around and updates fix things lol it's a never ending cycle and now that they are doing it to cars much more frequent than they ever have in the past expect more headaches in the future.
first it was mechanical part issue's and now it is both software and mechanical combined. troubleshooting these things is going to be a nightmare down the road when the modules start getting goofy and only work part time or boot and freeze or do other erratic behavior. most modern phones barely make it 2-3 years before they are simply either just flat out outdated or the internals start to fail, I don't really see the new vehicle electronics being that much better but time will tell.
Fless
Super Moderator
Elev 5,280
Emily does a pretty good cover of "Whiter Shade of Pale."
Fast_AT4
RWM +1
SW Florida
Notified about an updated. Opted to do it in my driveway vs out and about. It failed to complete and then notified again about the update.
..round and round -Ratt
Fossil Fool
