Wheel interchange 99 Yukon
Eman85
Have a 99 Yukon 4wd. with the factory aluminum wheels, actually I have 3 and need a 4th. Not having much luck finding a single and they aren't the nicest looking wheels anyway. What years and model factory wheels will bolt on with no problems. I'm not looking to do any modifications, just want it for a daily. I guess I'd rather stick with 16" stock size tires 245/75/16. Are all of the wheels from 88-99 the same width and offset? What about later years?
east302
Mississippi
The six lug pattern is the same for the subsequent 99-06 Silverado (GMT800 platform) and is a common swap. Later years are probably the same.
From a random search, rims from a 99-02 (plus or minus) Silverado:
InterceptorF
COlorado Springs CO 80908
Take a look in your local Upull and Upay if you have one around. Stock rims everywhere laying on the ground to simply pluck; every kind imaginable at least in Colorado Springs Upull Upay.
Our UPulls generally have a bunch of racks in a specific area with wheels for sale.
E
Eman85
Pull A Part is a long way from me but I went and looked. They don't pull and rack the wheels, they are just laying around the cars if they've been pulled off. They didn't have what I needed. Did get lucky at a local small junk yard so I found the wheel I needed.
E
Eman85
This Yukon came with 245's will I have any problems if I go up to 265's?
east302
Mississippi
265/75/16 was a factory option so no issues there.
You can fit most 285/75/16 on them as well (BFG AT for example).
For different rim sizes, compare overall tire diameter.
audley71
