Wheel lights fuse blown
McLeod Crouch
McLeod Crouch
Hey guys thanks for the help. I found out that if i flip the add a fuse around it stopped blowing. I think it was some how pulling heat or something from the other fuse or fuses. BDE30E05-F462-453D-B720-72742AC5DD11.jpeg
McLeod Crouch
McLeod Crouch
Hey guys thanks for the help. I found out that if i flip the add a fuse around it stopped blowing. I think it was some how pulling heat or something from the other fuse or fuses. View attachment 379239
Nevermind.. it only blows when the truck is on. If the truck is off they work fine. Once the truck turns on it blows a second later.
Gambles
I run the oracles with no problem, however mine are all powered and grounded to my own fuse panel under the hood in pairs, with a 2 amp fuse on each circuit triggered by a stand alone relay are you sure you are fusing properly in the add a fuse? If you are using them backwards the 5 amp is popping because you added a new circuit onto an old circuit and cut the fuse rating in half basicallyIMG_0624.JPGIMG_0624.JPG
Dremar79
