Wheel/tire sticky 07 up
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
Guys like I've done on the s10 forum to help others if we can get get people to list
1) year of truck/model
2) wheel size/offset
3)) size tire
4) how much of a drop
5) If it rubs
Just trying to help others out with wheels/tires and drop kits they are looking for.
Let me start with a few of mine
1) 07 tahoes/yukon etc
2) 24x10 30-35mm offset
3) 305 35 24
4) 3/5 drop
5) little rub on top fenderwells in front and in rear with cut bumpstop brackets tire does not hit fenderlip.
1) 07 up tahoes/yukon etc
2) 26x10 35mm offset
3) 295 25 26
4) 3/5 drop
5) no rub at all even in rear with cut bumpstop brackets tire does not hit fenderlip.
1) 07 up tahoes/yukons
2) 24x9.5 38mm offset
3) 305 30 24
4) 2/4 drop
5) no rub at all and in rear even with bumpstop brackets cut off frame tire does not hit the fenderlip.
AZSCTACO
Phoenix, AZ
2) 22x9.5 +30mm offset
3) 305/40/22
4) 2/3 drop (belltech 2" drop struts front - belltech 3" drop springs rear with belltech shocks)
5) no rub in front, minor trimming in the rear....only rubs a tiny bit in the back when going into a driveway
KMeloney
Tony -- Might it be helpful to list the BRAND of drop you're listing? Only then can you determine if a pattern appears within a certain brand/configuration.
vietcu
If I go with
24x10 +30 offset
2/4 drop
305/30/24
will I have any rubbing and will the wheel fit inside or stick out a bit? Or should I go with +35 offset instead?
k9lovr
Virginia
20x8.5 +25 offset
2" Belltech Front dropstruts
3-4" Belltech rear springs
275/55/20
NORCAL SS
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
If I go with
24x10 +30 offset
2/4 drop
305/30/24
no you will be fine but wiht 305 30 24 i would go with the 3/5.5 kit i have it will ride very nice
bruh2125
