When the ac is running I don’t like the noise
OR VietVet
Multnomah Falls
Military
Willamette Valley
Is that noise from under the hood or inside? I assume under the hood. Does sound like compressor problems or just the clutch. I also assume it only does the noise when clutch is engaged.
S
seatown
Under hood
Only when ac running. Ac clutch?
Seems like it gets a little better when warmed up… maybe…
OR VietVet
Multnomah Falls
Military
Willamette Valley
On the front of compressor is the clutch. When a/c is off, the belt spins the pulley when engine is running. When you turn a/c on, the clutch in front of pulley is magnetically sucked against the spinning pulley and the compressor is splined to clutch and the clutch turns compressor.
S
seatown
All bad new guys.........
c'mon........
any special tools for this job? might be something I just find a local ac guy to deal with.
Rough cost?
OR VietVet
Multnomah Falls
Military
Willamette Valley
c'mon........
Rough cost?
I am gonna make a recommendation. Since you did not know what the a/c clutch is, we all started learning somewhere, I recommend either a qualified friend help you or a qualified shop do the work.
Bryon Morgan
